1989 240sx ka24e manual transmission reverse problems
adidas13
Car: 1989 Nissan 240SX XE
Hey I have about 246,000 miles on the ka24e. The problem is getting my car into reverse. The actual shifter will not go into reverse gear.
When I do get the car into reverse and I start moving there is this loud scraping noise coming from the bottom of the car in the back. I thought something was scraping against the exhaust piping but I am not too sure.
I was planning on exchanging the transmission fluid to see if it improved. After that I am not sure what else to check.
any help will be greatly apprecciated.
180fan
Car: 89 fastback
replace the fluid, otherwise I have a feeling your reverse gear is toast. when changing the fluid, check the drain plug and also the fluid for excessive metal bits floating around in there.
omdella
Car: 89 240sx hatch
if that dont help sound like ur reverse synchro is all jacked up
adidas13
yeah I will definitely change the fluid. I didnt think about the synchros thanks for the input.
