Well, I changed sparkplugs, removed corrosion along parts of the wiring harness, and it will run sort of..
It will not idle, and I can rev it up to 2500 RPM, afterwards it loses power or sounds sort of like the rev limiter...
Takes a while to start it like that..
When I had it running, I put a cane on the accelerator to keep it revved around 1.5k rpm so it wouldnt stall, and I removed a plug to each injector, one at a time..
Doing that to each one you noticed it really started getting choppy, I put the plug back on and it was fine, did that to each one with same results..
I am really stuck on this one :-(
Does anyone know what it could be, tomorrows plan, if I have time is to take out the fuel injectors and see how clean they are...
Thanks,Josh
