Acecool »
https://forums.nicoclub.com/acecool-u46759.html
Tue Sep 12, 2006 3:06 pm
Alright I am back..
My car is running, but I got a rough idle when it was cold... when it was warm (after highway, it seemed ok, but just just after the highway it was shaking and lurching forward a little...)...
What I have done so far:Cleaned the plugs to all injectors, replaced sparkplugs, checked spark plug wires and distributor cap, cleaned two more plugs at the back of the engine... and messed with the MAF plug..
I had this problem a while back, around the 2500 to 3k it is hesitant to accelerate cleanly and smoothly.. Now it is doing that, and hard to get the vehicle in motion...
Some people said to remove the AIV, does anyone have any PROS and CONS for this job aswell as some pictures explaining what and how to do it (I have searched, only found one thread on this forum and several on another but not really too detailed...)...
The airfilter looks clean, but when I pick it up I see dirt underneath it sitting on the plastic part that goes down..
The little tube that goes into the air thing, if I lift that up you can look down where the front left headlight is, that has dirt in too.. What is the best way to clean these..
What I will try..
Cleaning the MAF plug, Taking the injector plugs out, one by one to double check that they are working correctly.. and I am stuck from there, any ideas?
Thanks again,Josh
