1989 240SX Hatch - Cleaning the fuel system, dropping the gas tank, etc..
Acecool
Car: 1989 Nissan 240SX Hatch Pig KA24E 126k
Alright, I am suspecting as part of my hesitation problem, is maybe bad gas.. When I am low it stutters and hesitates, but when I have a good full tank, then it only stutters when COLD...
I wanted to wait until my tank was near empty, take it out, replace the fuel filter, replace the injectors, and clean out the gas tank, maybe even replace a few tubes (Or, could I send somthing through the system to clean it out? How?)
Does anyone have a few pictures on how to do this, aswell as gas disposal places in Charleston SC or surrounding areas?
Thanks in advance,Josh
Oh, I checked at a shop, they said they would charge 300 or more just to take the gas tank off...
ricebike
2002 Quest
2005 Altima
u can just pull the fuel pump from the access panel in the trunk... so no need to drop the tank...
just need to have a siphon/pump type extractor to get rid of the bad gas...
most likely need a new o-ring for the access panel--> from a stealership or a dealer-nico sponsor
Acecool
Awesome, But what if there are particles floating in there?
Would it be better to drop the tank and force some good gas through the system?
Thanks
ricebike
2002 Quest
2005 Altima
<shrugs> i guess...
keep in mind, u & I got 17 year old straps & rusted on bolts holding the gas tank up, so prepare for that extra expense if you cross that road.
u gotta pull the fuel pump off anyways thru the access cover in the trunk... new o-ring-->check!
mebbe when you see the fuel sock/strainer @ the end of the fuel pump, that may have to be replaced as well...
Acecool
Oh wow, heh, I hadnt thought of that..
I am getting my radiator replaced tomorrow, with a flush of the coolant system..
When I get my injectors in, I may do that though..
Thanks, do you have any pictures by the way?
Josh
ricebike
2002 Quest
2005 Altima
ooh, the cooling system; B 100% sure that you've burped the system of all air... search on that too...
yup, after replacing fuel filter & seeing if the strainer/fuel screen/sock is crap-free... you'll be ok...
u can just pump out the bad gas, put some solvent in the tank... swish it around w/ a broomstick.. pump that shizzle out... replace the pump w/ new 0-ring seal... filler up & X yo fingers.
PS: i did have a few pix on the gallery section, but i think they're currently revamping the system it's just a stock daily driver w/ a roof rack anyways
Acecool
Hey, I am paying to have the radiator done :-(
But, The gas thing shouldnt be too difficult since you relieve fuel pressure when you change the filter and gas up so...
Josh
ricebike
2002 Quest
2005 Altima
oh shizzle... i can aquire a brand new rad for $89 shipped to your door... then I'll help ya install it for a box of pizza...
oh wait, u r not in nj... gl then!
Acecool
Heh, I would have gladly gotten you that and a case of beer (You are 21 or older, right?)
I saw OEM ones on eBay for like 80 bucks shipped, but I didnt want the plastic tank again, mine blew :-(
Josh
ricebike
2002 Quest
2005 Altima
yeap, no a case o soda would b betta... i don't drink
all metal one w/ lifetime warranty fo $89...
GL w/ your car's maintenance!
