1989 240sx Handbrake Cable.
gtprince
Hi. i bought this car and i knew it does have a handbrake cable. i've used the search tool and i still cant find out to see where the cable goes is there a walkthrough that i could use thank you.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Welcome to NICO.
The E brake cable goes from inside the car thru a hole in the tunnel back to the rear suspension. There are various places you can adjust it, and someone else might be better off telling you how to adjust your E brake.. You cant really get to the cables under the car terribly easy because theyre covered by the exhaust (I think)....
180fan
Car: 89 fastback
covered by the driveshaft and surrounded by the rear subframe and rear links...
Acecool
Car: 1989 Nissan 240SX Hatch Pig KA24E 126k
You can adjust it straight from inside your car, there is a hold in the ebrake boot.
gtprince
srry i mean that their is no cable at all. so does any1 know where i can learn to install one i'm short on cash as it is/
180fan
Car: 89 fastback
you can figure it out from looking up from underneath the car. you'll need the cable that runs from the ebrake handle, the adjuster nut, and the two ebrake cables that run to each rear wheel.
gtprince
thanks alot i really do apreciate it. do u have a picture of the two nuts that u were talking bout like by the wheels
180fan
Car: 89 fastback
two nuts? no, there is an adjuster nut at the ebrake handle. Lift the ebrake, and you'll find a hole in the rubber boot, in there with an 8mm deep socket you'll twist and turn an adjuster nut for your ebrake. The two that split off to your wheels are the ebrake cables. You can't miss them, they mount ala bolts to the caliper.
gtprince
bro
NUFF LOVE
thanks alot i heard this is like 200 dollars by a mechanic much respected.
