slayer6o6 »
https://forums.nicoclub.com/slayer6o6-u31510.html
Tue May 23, 2006 3:34 am
The name of the programmer/seller is Hirata Miyamoto. He is selling them on ebay-did I screw up getting my eprom there? He claims to be a Nissan Engineer and the eprom seems to be working ok. I soldered it in myself, no real problems there, and everything seemed to be running fine up until now.
I replaced the coolant temp sensor yesterday and I am going to have the time to see if that was the problem today-oh yeah, the old temp sensor had corroded terminals and the harness plug was in pretty bad shape too. Is there a place where I can get a new plug to splice into the old wiring? I thought that I saw somewhere that I could, just not sure. I am also going to check my ecm codes for any issues it might have found and test the fuel injectors for a sticky one.
You guys have been great, and I know that this problem, having read most if not all of the other forums on this and other problems, could have been many things. I also didn't mean to repost this issue...
Also could anyone tell me where to find a good how to on shimming hydraulic lifters? Since I have one that is making one hell of a noise now, I want to try that before disassembling the head again to remedy this problem.
Thanx again all!
Ryan
