Here's some reference photos for you.
-The brake pedal assembly switches. One controls the cruise control cutoff, the other is the stop lamp. When the pedal is in the resting position, the switch is kept in an open state. When you push the pedal in, the switch closes, completing the circuit. Normally it rests against a plastic stopper, and when that fails, the switch acts like you have the pedal depressed all the time since nothing is pushing against it.
-Clutch interlock switch.
