agne24us »
https://forums.nicoclub.com/agne24us-u9236.html
Thu Aug 21, 2003 8:46 am
i just had the same exact problem i just fixed on my car, my clutch out of the blue started slipping, and i thought the same thing, clutch is worn time to replace. i was wrong, i had a occurance about a month prior where the clutch master cylinder drained empty, so i refilled it and monitored it for a leak, i never found one, so i figured that all was well. it turned out that i then had the slippage happen. i figured i would replace the clutch and i did, then after two weeks it slipped again. it turns out that after i rebuilt the master and slave cylinder, that the system would not bleed correctly, finally after i dismantled the entire system , i found that the thick line on the dampner still had air in it, and i filled the line with fluid, and reassembeldthe system, i then bled the system again and now it works perfectly.
