1989 240sx clutch damper
dodge55
Anyone know if the clutch damper is a dealer only part? Can't find one at parts stores. I try to stay away from dealers if I can. Parts are way too high.
IvoryJ30t
Car: 95 Maxima GLE, 95 Maxima GXE
just bypass it. its useless anyway.
dodge55
I can do that. What is it's intended purpose?
IvoryJ30t
its along the hydraulic line from the clutch master cylinder to the clutch slave cylinder.
all it does is impede the flow of fluid to make clutch engagement smoother.
im assuming your replacing it because its leaking. it is not an essential item.
IvoryJ30t
you clutch will feel more direct and quicker without it.
TurboKA37
I know NISMO offers a steel-braided clutch line to bypass the clutch damper but are there any other cheaper alternatives to bypassing it?
IvoryJ30t
i dont remember exactly where the damper is located, but if it is located on the steel hard line, here goes-
go to the auto parts store and get some steel brake line with ends. bring your line to match up sizes.
take it home and bend it by hand. connect up, bleed system, and your golden.
steel brake lines are cheap. probably cost you all of $20 to do unless you cant do it yourself and a shop does it.
robertwb70
Car: 72 datsun truck=PL-521/on 85 frame Z-24eng+cam+ported+weber38DGAS
actually all you need are a couple plugs to plug off the tubing loop that is the damper-on a 1992 anyway-not sure about the s14/15s
