crookedcop7 »
https://forums.nicoclub.com/crookedcop7-u34140.html
Sat Nov 05, 2005 7:54 pm
I am having a problem with my dash warning lights staying on after I take out my key and I trie disconnecting every thing i can imagine....every plug from the engine harness and every relay in the 2 fuse/relay boxes in the engine bay. I even disconnected the dash plug going to the ecu that we usually wire up for the SR swap.
It seems to keep me able to turn the turn signals on and stuff. I even tried making the lights stay on .....then disconnecting the ignition key cylinder harness (6 pin plug) and the lights remain on. I even took of the connection to the alternator (power, ground, 2 wire plug) and it still remains a problem
HOWEVER. When I took out the junction box in the driver kick pannel and i Turned it around and took out the blue little 4 pin relay. It made the problem go away......but I dont want to resolve it like this. I want to get down to the problem and solve this correctly. I even tried taking out the diode pack from behind the radio......I am soo stumped and I know it has something to do with the circuit involving the bulb check relay..........I tried testing the relays by adding power and ground on each one to posts 1 and 2, and they click and make continuity......I am soo stumped . Also I found out that at the "bulb check relay" the brown and the red/black wire when the key is on holding 12volts with the key is off its holding 4.5volts theres a bigger blue relay near the "bulb check relay" that when you tap it the lights turn off please help adam
