1989 240sx : Cluster and tail lights out.
180sx
My gauge cluster on my 89 fastback doesn't light up at night when I turn on my headlights. But my turn signals will blink on the cluster when I use the turn signal.also speedo /rpm works.It started by flickering on/off fewtimes one night and than just died . All fuses are fine inside thew car, dunno about under the hood.I noticed few days ago my rear lights don't come on neither ,dunno when that happend or if its related to cluster.
while checking fuses i noticed few were the wrong size 20amp instead of 10 etc, so i replaced them with proper once still no go ... who ever owned this car before using wrong fuses
NISTECH
Open the hood and replace the blown fuse for "tail" lights. If it isnt blown you have an open wire some where in the circuit.
please follow the guidelines when posting and read the stickies at the top of the forums before you post in any forum.
zerothread?id=143819
97ka-t
Car: 1996 Nissan Maxima
1998 Nissan Altima
I'm not sure about S13s but my tail light was in the interior fuse box. It fixed my problem!
tonynalli
i had the same problem, is in kick pannel.. i also assume that your interior light doesnt work nor your clock along with your seatbelts
180sx
NO ACCTUALLY everything works, but the rear lights and dash lights. i took my cluster out there is a purple wire hanging? where does that go? all fuses are good there is no rear light fuse under the hood.
at night i hear rickeling, checked i can see a small spark escaping from my spark wire in #2 right near where it plugs into spark#2
180sx
and my car boggs around 3000rpm in 2nd gear alot if i let go off the gas and hit gas again goes past 3000k no problem , but it may be related to my dash lights so i dunno.
