1989 240sx Belt diagram
1990nismo!
Car: 1990 Nissan 240sx
Ok so i just bought another 1989 240sx but the previous owner changed the way the drive belts were set up. So i need to know the factory settings. Pictures will help. If anyone knows as to why the fan stays on all the time then that will help too. I hate sounding like an airplane coming down the street.
Red coupe
Car: 92 Nissan 240sx Coupe
A.) SearchB.) 240sx forumC.) Factory service manual (see A.)
Cone Junky
Car: S13 fastback
BMW e46 328i
They aren't serpentine,so it's pretty straight forward and I don't know how somebody could re-route these belts.
Inner belt-dampner, tensioner, ac compressor
Middle belt-alternator, water pump/fan clutch, dampner
Outer belt-p/s pump, tensioner, dampner
The fan clutch will always be spinning, that's the point of the fan "clutch". If it's making a lot of noise on acceleration, you're fan clutch is probably bad and constantly locked.
1990nismo!
thank u i figured out the fan clutch issue and i sound quiter believe it or not this guy had changed the way it worked...... he hadnt actually changed the setup its just i couldnt tell till i had it on the lift the day after the post....... thanks anyway car runs fine now
