FRoSt415 »
https://forums.nicoclub.com/frost415-u52531.html
Sat Dec 23, 2006 7:24 pm
just did a a/t to m/t swap rather simple just need all the right tools. parts needed are as follows:1. manual transmission driveshaft2. manual transmission (maybe upgrade depends on ur budget)3. manual transmission crossmembersince transmission is out might as well replace flywheel and clutch.4. flywheel(upgrade if you want)5. Clutch(go with the clutch kit stage two if you have mods on the car)6. clutch slave Cylinder7. clucth master Cylinder8. clutch line9. clutch pedal( break and gas pedal not needed but if you want you can obtain it. brake pedal can just be cut and grinded down. gas pedal is basicly the same as the auto.10. pilot bushing(since your already down there might as well replace pilot bushing.not needed but.....)11.throw out bearing(same reason, why not since your already their????)12. shift boot,and o rings on top and under the boot.(reuce noise coming from engine and seals off outside from inside of your car)All i can think of right now if i forgot anything just add to list. If DIY i recommend searching all related threads to gain the knowledge and have a heads up before going up the car. good luck and i would like to see pictures of the swap.
