K »
https://forums.nicoclub.com/k-u38292.html
Sat Nov 04, 2006 1:11 pm
Anyone know what the exact specs are for the alternator tensioner bolt? It snapped on me while replacing my water pump. I'm not referring to the two bolts that hold the bracket to the block, but rather the actual tension adjustment bolt. Don't know if it makes any difference, but this would be for an SOHC K series engine.
BTW: i spent the majority of the day trying to get the studs out of the original water pump as the cheap *** NAPA replacement didn't come with any. Ended up having to use some stainless bolts and some red Loctite. That's the last time i cheap out when buying replacement parts.
Thanks,K
