1989 240SX: additional maintenance to be done during clutch replacement
K
Car: 1991 GT-R32, 1993 MR-2 NA
Hello all,
I just purchased an '89 hatchback (bone stock) with 133k miles on the clock and it looks like it's time to replace the stock clutch. With a 240 of this age and mileage, what other things should i check on or replace at this time. Flywheel, rear main seal, timing chain?
Thanks,K
navysnail
get the flywheel resurfaced or replace it, check your rear main seal too as well as the seal around the transmission imput shaft. the timing chain is on the front so you don't need to do it at this time.
