1989 240 SX died on the way home
dinger240
Car: 1989 Nissan 240SX
1993 Nissan 300ZX
73 Ford Mustang Mach 1
92 Ford p/u
1989 240sx m/tcoming home yesterday the car turned off.Luckey I was able to coast home!checked the computer for codes 55.Did a spark check no spark.Car is stockrotor turns when cranked but tach does not move.where do I start
vancouverbc
Car: 1991 240sx
turn key to on position and listen for fuel pump to come on in back hatch.
dinger240
1993 Nissan 300ZX
92 Ford p/u
fuel pump works i don't have any spark
vancouverbc
Car: 1991 240sx
Not sure. I would first check the fuses. fuses in driver kick panel and in relay box next to battery.
NISTECH
check to see if you are getting spark from the coil to the distributor.
dinger240
1993 Nissan 300ZX
92 Ford p/u
no spark from the coil,I have power to the coil. The power transistior checksout ok.The coil is not open on ohms test.All fuses good.Any help greatlyappriciated
Thanks
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
There is also the resistor/condenser module to be checked.
vancouverbc
Car: 1991 240sx
blue=ground; red=12v+. I've forgotten my electronics:(
Modified by vancouverbc at 4:26 PM 7/21/2006
dinger240
1993 Nissan 300ZX
92 Ford p/u
Belive it on not it was a bad ignition coil passed ohms test.Replaced it with a new one BANG it fired right up. Hope this might help someone.
Thanks for the help:)
vancouverbc
Car: 1991 240sx
thanks for reporting back . This will help someone.
