1988 Z31, Rack N Pinion
A home for 1983–1989 300ZX owners!
NissanFairladyZ32
Car: 91, Twin Turbo, 99 Miata 1.8L
So i got the old one out easy, Put the remanufactured one on and for some reason the one of the power steering lines wont screw in ( the smaller one 15 mm)
I dont think the threads are bad but the screw wont seem to catch, ive tried multiple angles and still nothing .. is this commen? i got the rack from napa ..
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
they can be tricky, it should thread, it's possible the rack threads or your hose threading are damaged and preventing them form engaging
and be sure to use only ATF once you get it hooked up
NissanFairladyZ32
(Took it back thread was bad)
got another remanufactured one from oreilly's and that one worked fine bolted everything up with brand new outer tie rod ends & bushings
put ATF fluid and filled the sucker up turned from lock to lock a few times
Aligned the car, is it recomended for the toe on the front to be 0.9 ?
After my first drive the rack feels way too sensitive, is this normal ? is there a break in period for a new rack and pinion ?
(Car on alignment rack)
AZ-ZBum
Car: 05 Nissan Murano
84 Nissan 300ZX Z31 AE
88 Nissan 300ZX Z31 Vert
Alignment specs are on the back of the factory service manuals. Also, I believe they are in the Haynes manual.
What do you mean by "sensitive"? You can easily turn the wheel? The car starts turning with very little input?
NissanFairladyZ32
i mean the steering is way too sensitive while driving. I turn the car a hair to the left or right and the whole car shifts within a second
AZ-ZBum
What size tires are you running?
I would guess the alignment (specifically, the toe) is set wrong.
NissanFairladyZ32
im running the Z32 stock wheels with 20/55.16 all around
some guy in my class told me that these things dont need that much toe the alignment rack called for .9 we put it at like .4 or .5
but i did just change the rack and outter rods today maybe they need some time to break in ?
AZ-ZBum
NissanFairladyZ32 wrote:im running the Z32 stock wheels with 20/55.16 all around
20/55.16 is not a valid tire size.
0.9 what? degrees? inches? millimeters? **** hairs?
You really should learn to read a manual. Never trust those stupid machines to give you the factory settings. Look them up yourself. 0.9 isn't a number anywhere between any of the dimensions as prescribed by the factory service manual.
evildky
06 Nissan 350Z GT
toe out front makes for faster sharper turn in, not sure what the factry spec is but most likely it's a bit of toe in, I guess you just got used to the sloppy steering, I suspecct you'll get used to a car that steers as it should
NissanFairladyZ32
sorry 20/55/16 is what i ment
im pretty sure the 0.9 was degrees
AZ-ZBum
NissanFairladyZ32 wrote:sorry 20/55/16 is what i ment
20/55/16 isn't a valid tire size either. Do you mean 205/55/16 maybe? Do you think you could look at your tires to see what the real tire size is?
On Z32 wheels, you really should be running 225/50/16 anyway. That's also the stock Z31 turbo tire size.
0.9 degrees is HUGE!
Fine. Since you aren't going to help yourself, here's the answer.* 1 to 3 millimeters* 0.04 to 0.12 inches* 6 to 17 minutes* 0.1 to 0.2833 degrees
Do yourself a favor. Download a factory service manual here:http://www.xenonz31.com
READ IT!
NissanFairladyZ32
I set the toe to (0) today and the car feels alot less darty and drives alot straighter, thanks alot
Return to “300ZX (Z31) Forum”
