1988 Nissan Silvia Question
DjLiquid
Car: 1988 Nissan Pulsar
There's a guy who owns an automotive place here in Winnipeg and I found a RHD Silvia and was inquiring about buying it. He said it's a customers car and that he's intending on finding a motor for it but apparently he doesn't know anything about the car really. He wants me to come take a look at it again when I get a day off work to give him my diagnosis on it and to see what it needs. He already knows that the engine is blown and I believe since it's a RHD, it was imported from japan so it has all the OEM parts a ca18det would (ca maf, ca18det ECU, etc).
Now here is my question. Is this actually a ca18det or an sr20det?
Thanks.
themadscientist
CA, SRs came later. That's lucky for you cause SRs suck! Check the tag on the firewall near the master cylinder to find out what it originally came with, it will say either CA18DE or CA18DET. DET is good because that means R200 LSD rear, CA18DE means R180 one-wheel-wonder.
Seishuku
Car: 1987 Nissan S12, 5-speed, SR20DE+T 50trim T3@15PSI, Megasquirt 1 029y4
The Mk2 S12 turbo's from japan came with CA18DET's, Mk1 turbos came with the CA18ET or FJ20ET.
themadscientist
whoa, get a clue Mad, 1988=S12. Sorry bout that. Ooooo I hope it's an FJ. Does the hood have a bubble or is it one sheet of steel?
float_6969
*crosses fingers and hopes for a bubble
Hey TMS, can you hook me up with one of those one-wheel-wonder CA18DE diffs? More specifically the gears? Shoot me an email HERE.
Seishuku
themadscientist wrote:whoa, get a clue Mad, 1988=S12. Sorry bout that. Ooooo I hope it's an FJ. Does the hood have a bubble or is it one sheet of steel?
Not likely. 87+ are Mk2, those S12's didn't have the FJ option AFAIK. If it does, it would be the non-turbo FJ.
float_6969
*dreams dashed all to hell...
themadscientist
yeah if only someone had FJ parts piled up in him front room and an FJ Skyline pars car, if only,,,,,,,,
biosehnsucht
it CAN be a S13. You need to find out what the firewall tag says.
http://www.zeppan.jp/nissan/silvia.htmh ... /180sx.htm
The first S13 Silvia sales catalog is for May of '88, although the 180SX wasn't released until March of '89.
At some point in the past this topic came up on this very forum, and it was shown that the S13 Silvia did exist in 88, if only for part of the year.
To back this up, Nissan FAST lists the production span of the S13 Silvia as being 05/88 - 10/93.
themadscientist
why the hell can't automakers release models in phase with the gregorian calendar?!
Dattebayo
Youre the first person I have ever known to refer to nissans as Mk1 and Mk2. Thats so wierd.
Seishuku
Two different generational releases of the same body, what's so weird about that? In japan it marked a slight style change (mostly front-end, grill, parking lights) and a motor change (FJ20ET -> CA18DET for example)
mikesim
it's an S13 silvia. the owner talked of an RB swap one time, but i don't think the garage knows anything about that. i think he'd be on his own installing and wiring an RB in there.
well, not entirely on his own, he has this community.
nocwage
biosehnsucht wrote:it CAN be a S13. You need to find out what the firewall tag says.
My Silvia K is a 1988 Silvia K(w/ CA18DET)Is there something I can take a picture of to "prove" it?
sil_eightyRPS13
Car: 1989 RB27 cefiro
mine as well is a s13 1988 silvia K's
biosehnsucht
well statisticly speaking most 88 silvias will be s13 since they were made for 2/3 of the year ...
you can always take a pic of the firewall tag, but you don't have to prove it, really. if you say it is, we're not going to argue. it's not like you can easily confuse a s12 and s13 when you're looking at them.
NeedCAforS13
Car: CA swapped S13 coupe
2BN_S13 wrote:Youre the first person I have ever known to refer to nissans as Mk1 and Mk2. Thats so wierd.
the s12 guys are big into mk1 and mk2 http://www.club-s12.org uses the mk1 and mk2 names frequently...
Sean
float_6969
I agree...
flohtingPoint
Car: 2004 Z16 Corvette Z06
Sean
lol, being a former DSM head I call them 1g and 2g frequently
