1988 d21 bad noise timing chain??
bbar
Car: 1988 nissan d 21 pick up 1991 nissan sentra
Hi,
Have a 1988 d21 2.4 175,000 miles. Has slowly developed a bad scraping/clattering noise which sounds like loose timing chain. Have been told there are guides that can be checked/replaced that you can do without tearing the engine apart and may solve the problem. Please give me info on these guides , where they are located, how to take them out to check and whether this may be the problem. Thank you
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Everything is located behind the front timing cover. The KA and NAPS-Z have similar step involved in replacing the chain and its guides. We have lot of info floating around the forum on this topic.
TeslaTrooper
Car: 88 nissan truck
I do not know if this is relevant or not, but I just got my truck for cheap because someone put a cheap a** timing chain set on my 88 Nissan that allowed the timing to skip and ruin the head. (it cut grooves between the cylinders backfiring as it was drove home)
I got another head used and a shop showed me the tensioner didn't even have a locking mechanism, just free floating. No wonder it skipped!
My only advice is to get good quality parts on the set and tensioner as it DOES make a difference.
