1988 300 ZX Turbo Motor Swap Options?
A home for 1983–1989 300ZX owners!
88300zx
Car: 1988 300 ZX
What is the best motor swap option for a 1988 300 zx vg30et?
Thanks
Modified by 88300zx at 10:32 PM 8/9/2007
AZ-ZBum
Car: 05 Nissan Murano
84 Nissan 300ZX Z31 AE
88 Nissan 300ZX Z31 Vert
It's pretty obvious you haven't done any research at all.
1. The turbo is a VG30ET, not a VG30DET.
2. The VG30ET has made over 400hp with basic mods. A junkyard VG30ET has actually made 800hp with just external parts like big turbo, new intake, exhaust, and a small shot of nitrous.
3. The cost of swapping in a VG30DETT will end up running you anywhere from $2,000 to $10,000. Since you're asking this question, you haven't actually sourced any parts or know what you're getting into. It will probably run YOU closer to the $10,000 mark.
4. The amount of money you would spend on doing a swap would better be spent building a more powerful SOHC VG motor.
88300zx
Car: 1988 300 ZX
well lets say upgrade is the answer where would you start with the stock motor, assuming i have around $2500.00?
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
is the motor running? compression good? if the mtoor requires work that has to be priority, and wile you have ti apart, metal HG's and ARP headstuds are money well spent!free flowing intake and exhaust, big turbo, big fuel injectors, FMIC and romulator or some other means of tuning for the larger injectors and turbo will get you 300-400 whp
also remember that a motor spwa is never as cheap as you think, once you buy an RB25 you's still have to modify the oil pan, pickuptube, crossmsmber etc, and still need to add intercooler piping etc
Flicktitty
Car: 1989 Nissan 240sx 2JZ-GTE Swapped
1994 Toyota Supra
2019 Lexus GX460
1992 Lexus SC400
keep the VG30ET in it. I WANTED to do a motor swap in mine i just didn't have the time/money or skill. and judging by your post you don't have any knowledge of the car to begin with.
Big_E-Dog
Car: 87 nissan maxima
vg33e6 vh45 pistons swap pistons into the vg33 block+ vg34e add bigger injectorsvg30e turbo manifilds w/ turbo headsfat a$$ intercooler
vg34et
hp unknown
Return to “300ZX (Z31) Forum”
