1988/1989 300Z Can't find coolant sensor
A home for 1983–1989 300ZX owners!
thewildthang
Car: 1989 300Z
The subject pretty well states my problem. I've been from one end of the engine to the other and I can not find the coolant sensor. I've found the temp sensor that works the gauge, I found and replaced the head temp sensor yesterday while changing the timming belt. The ecu indicates a problem with the coolant sensor but I can not find the darn thing. HELP!
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
the coolant temp sensor is on the intake manifold, it's a one wire spade terminal, on the passanger side, below the plenum between the injectors
and the coolant level sensor is in the bottom of the coolant resivoir
AZ-ZBum
Car: 05 Nissan Murano
84 Nissan 300ZX Z31 AE
88 Nissan 300ZX Z31 Vert
The sensor for the dash is on the right side of the engine's lower intake between fuel injectors feeding cylinders 1 and 3.
The sensor for the ECU is in the front of the left side head, more commonly called the cylinder head temp sensor.
If the ECU is still pulling that code, it's likely the harness is damaged.
This is assuming you cleared the codes before checking them again.
Return to “300ZX (Z31) Forum”
