ah s*** pretty sure I have a vlsd but I hope not cause I know the ss everything is hard to comeby. tried finding springs and shocks from that awhile back nearly impossible.evildky wrote:The CLSD has unequal length stubs, the CLSD and open diff models inboard stubs are equal length and interchangable between models and left to right. The turbo cars had a 4 bolt complanion flange at the wheel side, the n/a's got a 6 bolt flange. If you car has the 4 bolt companion flanges and an open or clsd then the standard turbo shaft will bolt right in. If you car has the 6 bolt companion flanges you'll need the n/a shafts. If your car has the VLSD then you need the 88 ss shaft which is hard to come by.
thanks for your help I found out I have a 4 bolt flange after looking at it. one of the bushings is a little worn on the rear axel and the polyurethane boot is torn but the coilover/springs/shocks look in good shape but since someone stole some of my lugnuts my rim was lose and so was the spacer. So going to tighten lug nuts check the spacer,tighen it and then see how it is. Probably ride with the torn boot until I can replace the whole rear cv axel. So since autozone sells these parts do I just ask for a rear cv axel for an r200 lsd diff?evildky wrote:The CLSD has unequal length stubs, the CLSD and open diff models inboard stubs are equal length and interchangable between models and left to right. The turbo cars had a 4 bolt complanion flange at the wheel side, the n/a's got a 6 bolt flange. If you car has the 4 bolt companion flanges and an open or clsd then the standard turbo shaft will bolt right in. If you car has the 6 bolt companion flanges you'll need the n/a shafts. If your car has the VLSD then you need the 88 ss shaft which is hard to come by.
yea so far they seem ok and in good shape besides the bushing at the bottom and the boot but I thought if the boot got messed up then all that dirt gunk or whatever it picks up is getting in the cv shaft so u should just replace the whole thing or is that not ture.evildky wrote:when a cv fails it makes a clicking noise, and you can get under there and grab the shaft and move it around. A torn boot can be replaced sepperately, it's a pretty easy but messy job.
Yea I've learned from experience after taking off rim and calipers should probably replace the brake pads make sure the rotors aren't warped that sort of thing. We replaced the bolts that came out of the front calipers and got new lug nuts. When i get 18's I'ma put on new extended lugs and studs. The noise stopped suspension feels better and so does braking after tightening everything up. Now I just need to find 18 inch wheels probably was going for something like 18 by 9.5 front and then 18 by 10 or 10.5 rear want to try an even offset all around but stagger the wheels, or atleast have same lip all around not sure what would look better yet.evildky wrote:I'm not a fan of spacers, buy wheels in the correct bolt circle and offset and you have one less point of potential failure. And when working on brakes it payes to double check everything before it hits the ground, not something you want to risk.
