NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Tue Mar 09, 2004 8:44 am
yea it will work. ok if the terminals are marked 1,2,3 and 5 you need to jump 3 to 5. now use the numbers that are inside the terminal portion of the relay not the numbers on the top of the relay to match the terminals in the connector. now remember when your looking down into the relay it is upside down. The numbers are a little hard to see but you can see them with good light. match where each of those terminals would plog into the socket and jump them. with the relay out and those 2 terminals jumped try and start it. I cant stress enough though that you be sure to jump the correct terminals so you dont smoke your ECM.
