Ozzie »
https://forums.nicoclub.com/ozzie-u33476.html
Fri Aug 13, 2010 9:12 pm
Take it to a transmission specialist.
When you say you changed every clutch part, do you mean the flywheel (or at least get it faced), pressure plate, clutch plate, throwout bearing, slave cylinder, clutch lines, fluid reservoir, clutch fork, clutch fluid.
Are you sure you used all the correct parts, and didn't substitute them from different models? (tolerances may be different between models)
