1987 Nissan 300Zx Clutch Problems
A home for 1983–1989 300ZX owners!
karmaknight
Car: 1987 Nissan 300ZX 3.0L non turbo Z31
I bought my Z three months ago. The previous owner replaced the clutch, throwout bearing, and pressure plate. Also had replaced the slave cylinder and I'm still having problems with the clutch in engaging. I replaced the fluid with new and for about 5 weeks it worked well. Yesterday I noticed that the clutch pedal was back to the floor and after pumping it a few times still no petal. Before I could pump the pedal and it would be able to engage. Any help would be helpful!
FoxFire
Car: 90 vg30eT 240SX, s12 vg30e
check clutch fluid agian . also check the soft line that runs from the hardline to the slave cylinder for a leaky membrane.
AZ-ZBum
Car: 05 Nissan Murano
84 Nissan 300ZX Z31 AE
88 Nissan 300ZX Z31 Vert
Replace the clutch master and slave cylinders. Then replace the clutch damper with a brake hose.
Read:http://www.az-zbum.com/modific...shtml
karmaknight
Replaced the slave cylinder today, hose we be here tommorrow. We bleed the system and we now have a little bit of petal back. We will see if the mods work tommorrow!
karmaknight
We are happy to inform you that the car is running just fine now. The clutch is working better than ever, thanks so much for the information!
skyrickp21
Car: 87 nissan 300zx, 07 nissan frontier nismo
I am having the same trouble that you had.. The pedal is down to the floor.. What all did you do to get your ride back on the road and how much did you invest in the clutch operation..?
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
pedal = petal =
evildky
06 Nissan 350Z GT
skyrickp21 wrote:I am having the same trouble that you had.. The pedal is down to the floor.. What all did you do to get your ride back on the road and how much did you invest in the clutch operation..?
wow, well first fo all welcome to nico, I'll give you a waiver since you are brand new, to see what he did read the thread, to se what it costs go to autozone.com and check prices for your car, or any retailer of your choice
bigred240sx
Car: 91 240sx fb w/ super hicas(wrecked)
1976 280z
2009 frontier
wow evil that semmed harsh ahah...but its true
evildky
06 Nissan 350Z GT
well it's silly to ask for prices on stock replacement aprts when you cna quickly check at autozone.com or napaonline.com or any retailer of your choice, I understand if he were asking about labor of aftermarket parts
pigmouse
Car: 1993 240sx Convertible
The clutch damper really does suck.
Replacing it with the 280 brake line fixed my problem completely when I had this issue. Everything LOOKED ok on the outside, but kept having to pump the clutch at intervals to build up enough pressure to disengage the clutch.
AZ bum is definitely the man when it comes to z31 knowledge. I recognize the name from another forum I used to frequent back before I had to sell the 2 seater for child rearing...
FoxFire
A 240sx clutch line to slave cylinder works
Return to “300ZX (Z31) Forum”
