1987 hardbody clutch
squirrl85
Car: 1987 nissan hardbody d21
all clutch parts replaced and line bled but will not engage clutch any suggestions?
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
I'll move this to the hardbosy sections but, most nissnas have mroe than 1 bleed point, are you sure you led all the bleeders?
longtooth
Car: 89 d21 HB
Did you bleed it from the dampner on the fire wall half way down on the passengers side?
squirrl85
yeah and i tried filling it from bottem up and still no pedal
longtooth
Car: 89 d21 HB
Well did you put the clutch disc in backwords? Did you check to see if the thow out bearing fell out?
squirrl85
its all in thier right i vacumed the fluid from the bottem up but still no pedal dose the clutch petal have to pressed when do that?
346ci
Car: 2000 Camaro SS
1993 Hissan HB X-Cab
1992 Chevy S10 4X4
Clutch master and slave cylinder replaced?
squirrl85
yeah both bran new....
longtooth
Car: 89 d21 HB
With someone working the clutch and you see the slave cylinder move the shift fork?
CentralScrutinizer
Car: 1986-1/2 Nissan Hardbody 4x4 Z24I
I just did this. The clutch master and slave tend to air-lock; so you will need to pump lots of fluid through the line to get all of the air out. I used LuK clutch components (amazingly they were on the shelf at my local PepBoys) and Castrol LMA fluid.
I attached a bleeder bottle to the bleed screw on the slave cylinder and pumped the clutch 3 times then topped the reservoir. After bleeding twice there was light pedal but obviously not 100% bled. I repeated two more times and the clutch felt firm and correctly bled.
I also suggest that you replace the hose from the hard line to the slave cylinder; mine was looking like it would fail in a few more years (weathered and cracked). Your local Napa should be able to order it; but be sure and use the LMA or Silicone fluid because their hose is not compatible with Dot 3 petroleum fluids.
