Hi, I have a 1987 D21 Hardbody. I need help identifying it completely.
It seems everyone talks about 1986 or earlier and I am not sure if it is the same as a 1987.
It has a Z24 engine, 2WD, Automatic, and is a 4 Cylinder.
The main thing I need help with is the vacuum lines going to the air filter. I've looked all over for the correct description but the designs are different. I had gotten fed up and bought a Haynes manual and it doesn't help at all.
