1986 z31 starting problems
A home for 1983–1989 300ZX owners!
anthonay
Car: nissan 300 zx 1986
today i went up to my car to start it. i belive the cyllinoid is not gettin power due to the securtiy system not turning off when i unlock the car... does this problem sound common?? my mechaninc said that i should lokc and unlcok the driver then passenger door it worked the first time... but not after the first tiem.... today i messed with a wire "yellow" connected to the cyllinoid and it worked
SHIFT_Z
Car: On 4's
2019 Subaru WRX 6MT
Former:
2014 Chevrolet Cruze 1LT
2006 Nissan Altima SE-R 6MT
1988 Nissan 300ZX 2+2
1985 Nissan 300ZX Turbo
1986 Nissan 300ZX Slicktop
On 2's
2018 Kawasaki Ninja 400 ABS
Mods will be moving this to the Z31 section soon...
But I don't think its something with your security system if you're messing with wires and getting it to turn over.
IIRC, to disable the security system, you have to unlock, lock, then unlock the door again (driver side)
AZ-ZBum
Car: 05 Nissan Murano
84 Nissan 300ZX Z31 AE
88 Nissan 300ZX Z31 Vert
anthonay wrote:today i went up to my car to start it. i belive the cyllinoid is not gettin power due to the securtiy system not turning off when i unlock the car... does this problem sound common?? my mechaninc said that i should lokc and unlcok the driver then passenger door it worked the first time... but not after the first tiem.... today i messed with a wire "yellow" connected to the cyllinoid and it worked
What makes you think it's the security system?
Return to “300ZX (Z31) Forum”
