1986 nissan 300zx Rear end metal on metal noise
eonblu
Car: 1986 nissan 300zx non turbo
my z has a problem I need help fast, when engaging drive or reverse, then push accelerator, I hear a metal on metal sound, car also has vibration at 1500rpms and smooths out around 2200rpms is the drive shaft shot or is it something else
spiderwebfx
Car: 1985 Nissan Silvia S12
Check your brake pads. If they're worn down, the little still clip will be rubbing on the rotor to tell you they are worn down.
OriginalWheelman
Car: '15 Ford Focus Electric
If the Z31 has a carrier bearing in the drive shaft I would check it. If it's a clunk look at your universal joints. If it's a grind, look at anything that spins. Does it happen in all gears or just at low speed?
eonblu
Thanks for the response, I took it in and they diagnosed the universal joints, it would only happen as I would start out, forward and backward, as long as I don't gun it. if I start out at idle speed it won't do it. If you have anything else feel free to comment. Thanx
OriginalWheelman
That sounds like universals. They are very strong solid X shaped pieces of metal. On the end of each part of the X, a cap is fit with roller bearings on the inside. This allows the x to spin within the cap. The drive shaft is split so that one side connects to one line of the X and the other side of drive shaft connects to the other line in the X. The caps are pressed into the drive shaft. It allows power to transfer through the X without the two parts being in the same alignment. When the U-joints get old, the bearings inside the caps often disintegrate and fall out. This leaves a gap and the clunk you hear is the X hitting the inside of the cap. It's a very simple fix and the parts are generally cheap.
Dattebayo
It's simple and cheap just as long a you don't have to remove the exhaust to get to said U-joint. Just FYI.
eonblu
I truly thank you for you expetrise, I get what u r saying thanx for all of your advice you guys are awesome!!
