markmdz »
https://forums.nicoclub.com/markmdz-u94236.html
Wed Apr 09, 2008 10:08 am
If anyone could help me out, it would be greatly appreciated.
I bought an '86 hardbody V6 (4x4) from someone locally up here in CT last year. When I bought it, the previous owner did explain to me that it had a strange problem of not wanting to start right away if it's been running for a while, then I shut it off. He went on to say that if it sits for a few hours after it's been running, it usually starts right up without issue. (Example: If I drive to homedepot (about 20 mins from my house) and get a few things, unless I figure out a way to kill a few hours in the store, I'm SOL on starting it unless I pop the hood, remove the air cleaner cover, and open the butterfly on the t/b for a while to let some air in.)
So it seemed to me that there might be a bad (leaky) injector, or faulty fuel pump.
As soon as I mentioned that to the old owner, he told me that the fuel filters and pump had just been changed, as that was his suspicion as well.
I don't know of a way to check the injectors without actually pulling the top of the motor off, which I would rather not do considering the time and effort needed to do that.
There's a million other little 'maintenance' items I replaced as soon as I bought the truck too, and the problem is actually getting worse, not better. Now if it's just been idling for anything more then 5 mins, and I go to get on it, it stalls (then I get into the 'can't start it' situation described above) out or spits and sputters, burps (not a backfire) and takes off like a bat-outta-hell until the next stop.
As it stands right now, I consider it undriveable as it's too unpredictable, and stalls regularly.
Any help anyone can provide is greatly appreciated.
Thanks, -Mark D.
