1986.5 VG30i ECM Codes
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Here's a list of all the ECM codes for a 1986.5 D21 truck with a VG30i engine.
Code/Description
11= Crank Angle Sensor
12= Air Flow Meter
13= Cylinder Head Temp Sensor
21= Ignition Signal
24= Neutral/Clutch Switch (M/T) or Inhibitor Switch (A/T)
31= Load Switch
32= Start Signal
33= Exhaust Gas Sensor
42= Throttle Sensor
43= Injector Circuit
44= ECCS Normal Opertation
jp2code
Car: 1994 Nissan D21 Hardbody Longbed V6
2001 Nissan Xterra SE 2WD A/T
2004 Nissan Sentra
