1986.5 Nissian Kingcab with a 3.0 VG30i Cutting out issue
Docroth
Hello all
This truck was purchased with a blown head gasket. everything ws taken apart and labeled. Head gaskets were replaced, and the truck starts and runs wll, but I have missed somthing. As I rev the motor slowly with no load it cuts out about 2500 rpm. It then comes back on and repeats this over and over. If I rev the motor fast. I get the same result, only quicker. I know I have hoocked somthing up wrong, or have a broken wire, as this ran fine prior to my work.
Have any of you see this? Is this a vacum issue? or Fuel injection issue?
Is it possible to install the MAF backwards. I did not mark it and thinking back looks like I would install it backards.
I am also looking for a good Vacum diagram. Any thought or help would be great. this is my daughters pickup, and my gargage is being help hostage.
Thanks Doc
Docroth
Dose anyone have any thoughts on this? I figured all of you would jump all over this. Am I in the wrong Forum? Please direct me.
Thanks Doc
pejsa s-13
Car: 91 HardBody, 85 720
well i say go with your gut and try turning the maf the other way
did you mess with the timing at all?
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
I was going to suggest that timing might have something to do with this. Sounds like the ignition might not be advancing far enough off idle.
Docroth
Ok so the MAF sensor is installed properly, but I think I may have some vacum lines screwed up. Can anyone ponit me at any online Diagrams.
thanks again for your help.
Doc
seang
Car: Ford Fiesta ST
Docroth wrote: Can anyone ponit me at any online Diagrams.
http://arrc.epnet.com/autoapp/...L.gif
