1986.5 2x PickUp Hardbody Front End noise
RediNico
Car: 2005 Frontier Crew 4x4
PU has VG30i engine.Turn hard right or left while passing over bump or depressionand a loud noise emits from the area of the wheel going over the bump.It's a stress type noise. not really a grinding. Like maybe the shock is being stresssed
I know this is sort of vague, but hope it sounds familiar to someone.
All comments and suggestions appreciated.
CR
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
Steering stops maybe. Get under the truck and put a dab of grease on them and see if the noise persists.
Another possibility is loos bolts on the steering crossmember (the one that lines up with the front of the LCA mounts. Torque those down good as well.
RediNico
Thank DR
I was glad to hear that this is probably a simple fix.
What is LCA mount?
Cliff
Big-Bird
Car: 2000 Xterra on 'Roids & 2004 Quest SL
LCA = Lower Control Arm
You should also check the tension rod that attaches to the Lower Control Arm and runs up to a bracket on the front portion of the frame. Also check the front stabilizer and it's end links. The rubber bushings on these 2 items may need to be replaced.
See attached image.
RediNico
excellent.Thank you. The parts schemata is helpful.From where was that taken?I need to get a service manual.I have a Haynes from the library, but it seems to be limited.
thank youCR
Big-Bird
I scanned it from my own Haynes manual.
You just gotta know where to look...mind you I have been a Nissan trucks guy for 12 years so I know that manual pretty well.
RediNico
Yes, I see it in the Haynes copy I have.I remember now that I have a slightly different versionthan you. I'm going to have to purchase one and was wonderingif anyone had an optinion re: Haynes vs. Chilton?
CR
