1986 300zx turbo fusible link
A home for 1983–1989 300ZX owners!
A Furze
Car: 1986 300zx turbo
I recently purchased an 86 300zx runs great but the digital dash and lights don't work. The previous owner said it was the fusible link in front of the battery but it looks fine! Can i bypass it? Any helpful input would be greatly appreciated!
Reason: Deleted duplicate thread
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
The fusible links are int he little black box next to your battery. If you digital dash does not work it is likely the power supply which is under the dash. http://www.xenonz31.com/DigitalDashRepair.html
A Furze
i have a 1986 300z at about quarter throttle it dies, put a new throttle position sensor new fuel filter even dropped the tank and cleaned it, please help, love the car but cant drive it!!
evildky
06 Nissan 350Z GT
Have you checked the ecu for codes? Have you verified fuel pressure? Dieing off idle is usually either a bad fuel pump, or bad MAS. Could also be spark related, bad CAS, plugs, wires, cap, rotor button. If it works better when cold the CHTS would be suspect.
Return to “300ZX (Z31) Forum”
