1986 300zx n/a
A home for 1983–1989 300ZX owners!
sandiegozx
Car: 1986 300zx NT
Just bought my first Z it is the non turbo automatic trans
What are my best options for swapping the engine to a turbo engine and manual trans>?
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
Best Option, sell the car and buy a Manual trans turbo car. second best option is to buy a parts car that has the turbo and the manual. It's all bolt in but there are a lot of heavy parts and if just easier to start with the right car, if however you are attached to the chassis or stumble upon a wrecked turbo manual car by all means, do it. I used a donor, it's far cheap er than buying all the bits. You need:
engine
trans
clutch and brake pedal
clutch master
clutch hardline
front crossmember
ecu
driveshaft
you can either convert the wiring or swap the manual harness in
G-E
Car: 1. 1987 300zx Turbo-swap, SF interior, koni rallisport springs/struts, msa swaybars
2. 1997 Sebring coupe
3. 1987 300zx 2+2 becoming a caged racecar with RB swap...
You may also need the differential flange, trans mount and alternate speed sensor gear...
Return to “300ZX (Z31) Forum”
