FocoZ »
https://forums.nicoclub.com/focoz-u227125.html
Mon Nov 04, 2013 4:08 pm
Hey there,
I just picked up a 1986 300zx for $500 and I'm really excited about it. The body is really solid as is the interior. The engine is my only real worry as it runs very rough and is definitely missing. I have very limited mechanical experience, I just started a 2 year ASE program so hopefully down the line diagnosing and fixing something like this will not be a problem at all. I am not prepared to wait that long however, and so here i am asking you guys for some help.
The woman i bought it from said it had been running fine and then she let it sit for about a year before she decided to sell it.
I did a full tuneup, new plate, rotor, cap, wires and plugs, no change to how it is running. The plugs i pulled out looked as if it had been running rich.
i pulled the codes off the ecu and got TPS, EFT and MAF.
When i tested the TPS it wasn't variable resistance at all, just open and closed, is this how it should be?
The Engine Fuel Temp sensor's connector is very corroded, i haven't cleaned it yet, but could this be making it miss? Also the vacuum hose to the FPR is cracked and needs to be replaced.
I haven't done anything with the MAF yet.
I called Nissan and i was informed that there were no open service campaigns for the VIN of so I think that the fuel injectors were done.
I am trying to wrap my head around everything but i feel like i am just running in circles and tying myself it knots, any help or insight you can offer is much appreciated.
Thanks in advance!
