aris_unlimited »
https://forums.nicoclub.com/aris-unlimited-u92534.html
Tue Apr 29, 2008 10:37 pm
With some haynes/chilton manuals they have a diagram showing the wiring/hose paths. Although I personally do not know what they would be on your car. Also sometimes with a loose vacuum hose (not always but sometimes) just plugging up the hose (if that is the problem) will cause it to run better because then there is more resistance and it is not just free flowing.
As for a sensor that could screw all this up. A TPS (throttle position sensor) could mess with it pretty good.
As for timing. If your timing is off by quite a bit you will notice it messing with your car. But usually only being off by a couple of degrees will just cause it to run a little weaker, but it will still run.
Have you tried checking to see if it is throwing codes(unfamiliar with your car dunno if it even has a way to check).
Also if you still seem to have an issue figuring this out. Most of the dealerships around here will do a general diagnostic for about $100. So they may very well be able to figure out something we can't find.
Also when you do try to rev up the motor, will it rev up slowly but surely or does it kind of surge?
If it is surging it is very possible that one or more of your cylinders is not firing.........
I am going to feel like a complete dumbass if my hunch is right here........
But how long was the car sitting? If you haven't added fresh gas or put in a gas stabilizer before it sat it could cause all of this. lol. I am going to laugh if this is it.....
If this is indeed the case. Buy some fuel stabilizer put it in the car. Let it get good and mixed up then try getting the car running again. It will still be hard to get it going and it may very well still not run all that great, but it should run better. If this is the case add fresh gas in an attempt to dillute the bad gas. Although fully draining the tank and refilling with fresh gas would be the best answer.
