evildky »
https://forums.nicoclub.com/evildky-u13100.html
Mon Sep 03, 2012 9:22 pm
It's pretty simple, the issue is the fan is in the way, so you have to remove the belts and fan to get to it then it's just 3 bolts and you have to fiddle with the short hose to leads to the hard pipe.There is a bolt under that hard pipe that you can loosen to move that hard pipe a bit to make your life a bit easier.
