1985 maxima brake lights dont work
1989240sx
Car: 1989 240sx and 1974 duster
my question is i have a 1985 maxima the tail lights work fine the brake lights dont work check fuse i am at a lost any help would be great
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Unless I'm mistaken...Tail and brake lights use separate bulbs.
1989240sx
the tail lights work but not the stoping lights i am thinking it is the stop light switch
mtcookson
Car: 1991 Nissan 300ZX
1992 Iinfiniti Q45
and much much more
Might check the pedal itself. Usually there are some rubber pads that press the switch and its probably possible that they can fall apart or fall out after time. I'd check that, if the pads are still there you could do a continuity check on the switch. Just put an ohm/multimeter on the leads then press the switch to see if there's contact.
1989240sx
everything looks good i dont have a ohm meter to test them could it be a relay also what is the tail light tied with like the tail light and interor light are put togather
mtcookson
1992 Iinfiniti Q45
and much much more
I wouldn't think it would be a relay but it could be possible. I'd say it would probably be near the fuse box or near the back with the tail lights if there is one. I'd double check the fuses and bulbs again first as a relay is pretty uncommon to go out.
1989240sx
where is the fuse for the tail light i check all the fuses inside the car
mtcookson
1992 Iinfiniti Q45
and much much more
Well... if none of the fuses in the car are bad then that's definitely not it, shouldn't be any in the rear or engine bay for the tail lights.
I'll try getting out to the garage tonight and see if they have the relay location listed in the manual. Another way you can test the switch itself would be to unplug the switch and take a small piece of wire to connect the two wires together on the car side of the wiring. That would make them light up if everything is good besides the switch.
