mdjett »
https://forums.nicoclub.com/mdjett-u146872.html
Tue May 25, 2010 12:14 pm
The 2.4 that is talked about is the Z24i (the EFI Z24). It's in the late 720s and hardbodys through 89. Basically, it's the same engine except with EFI and slightly higher compression (8.8:1 instead of 8.4:1 if I remember my numbers right).
The Ka24E/DE are completely different on the intake side from the Z24s; they have 2 intake valves per cylinder and a totally different intake port shape. Either one would physically bolt into your truck and transmission (assuming you get a truck one with the right sump/pan, not a 240sx engine), but the downdraft setup won't work on it. There is supposed to be a factory carbed version of the Ka24 outside the US, but I haven't ever found one of the manifolds. All the carb conversions I've seen for Ka24s used dual DCOEs are were usually buit race engines.
