noface »
https://forums.nicoclub.com/noface-u156049.html
Thu Mar 25, 2010 12:12 pm
Thanks for the info on the PCV connections. I have the nipple and tube that connects to the intake, but the hose was missing that joins it to the tube that goes behind the block to the drivers side. A new piece of hose and I should be good.
Installed the timing chain today, started raining cats, dogs, and small people, so that's all I got done today.
Here's some pics...
The head gasket that started this whole mess. Notice the fire rings between #2 and #3 were deteriorating as well.
Cam timing gear marks and alignment. This is an aftermarket gear. Note the three different timing options, 3 holes that engage the cam dowel, and 3 corresponding timing marks at the outer ring. If you install the gear in dowel hole #1, you align the shiny chain link on outer ring mark #1, etc... I used the center hole #2, as you can see by the white paint marker....
I didn't get a photo of the lower crankshaft gear, but you get the idea... the timing mark on it is meshed into the shiny link, just like the cam gear.
This is my solution for retaining the timing chain tensioner. Installed it with the zip tie still in place, once located and bolts tight, cut the tie...
Now this is complete, I can turn it back over to my son to assemble the rest. He's with me through all this so I can learn him something, that way I don't have to fix his stuff all the time!
I'll get some pics of the oil pump, dizzy, and Weber going on as well.
Stay tuned
