noface »
https://forums.nicoclub.com/noface-u156049.html
Sun Mar 13, 2011 7:10 am
5 Speed trans in my 85 720 is taking a dump and need to replace it.
As we all know, the 720's use a divorced transfer case, meaning a traditional type trans with a short prop shaft on the output to drive the t-case.
So I'm thinking I can use a 2wd trans from a Hardbody truck. These trans are EASY to find, and tons of them out there available.
I know it will bolt up to the engine (in my case, I've already got a KA24E). But my concerns are total length of the Hardbody trans, shifter location, and is the output shaft the same (spline count/diameter - for the yoke).
Fabrication is not a problem (as long as within reason, mostly cost and time restraints).
Somebody's done this before, and I know there's folks out here that know the differences of these trans.. I need some advice (other than spend some time at the junkyard! LOL).
Thanks!
