1985 300ZX Z31 TURBO Locks
A home for 1983–1989 300ZX owners!
Stormhelix
Car: 1985 Nissan Z31 300zx Turbo
Hey.
How does one remove the locks on the T-Top doors off a 300zx z31 turbo 1985.
All i see is the electric system around the backside of the lock when I take off the panel. Is there a how to for the lock removal?
also, which Manual for the z31 300zx 1985 turbo is the best for one?
thanks.
G-E
Car: 1. 1987 300zx Turbo-swap, SF interior, koni rallisport springs/struts, msa swaybars
2. 1997 Sebring coupe
3. 1987 300zx 2+2 becoming a caged racecar with RB swap...
There's nothing electric in the t-tops, it's a standard cam that moves long pins in or out ...
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
Are you asking about how to remove the door lock cylinder from the door? Which does have an illumination ring.
One set screw IIRC, it's easier if you remove the handle from the car first which is just removing the rods, the electrical connector and 2 10mm nuts.
Stormhelix
Yes Evildky, I am asking how to remove it.
thank you so much for your response!
evildky
06 Nissan 350Z GT
As I think about it I think the illumination rang was held on by a single screw and the cylinder itself had a "U" clip that holds it in. Sorry all these cars blend together over time.
Return to “300ZX (Z31) Forum”
