evildky »
https://forums.nicoclub.com/evildky-u13100.html
Wed Feb 21, 2007 10:05 am
the basic coil over setup will work up front but the z31's rear will require some enginuity, the only ones I've seen looked unsafe, if there is enough clearance in the upper rear shock mount you might be able to drain the shock weld sleeve stops to the body of a rebuildable koni, ads, penske etc.
