evildky »
https://forums.nicoclub.com/evildky-u13100.html
Sat Dec 30, 2006 7:58 pm
Welcome to NICO!
this is a typical problem on the Z31's fromt he passanger foot well look up under the dash near the center of the car, you'll see 3 or 4 dashpots all in a row, on one bracket and kinda hard to get to, pull the vacume hose off of each and hook a vac pump to them, pull a vacume and see if they hold, if they do not hold you need a new diaphram, if they hold but pop as you pull vacume then they were only stuck, if the move as they should then you are likely not getting vacume to the selenoids, look at the vac lines under the hood going through the firewall, they get brittle and crack
as for the window it's likely just the switch, even if it is the motor the salvage yard is your best bet
