2kredz3 »
https://forums.nicoclub.com/2kredz3-u95007.html
Fri Apr 18, 2008 8:06 pm
Just bought it today Im happy, its a second vehicle for me. I am working on getting it daily drivable.
Work completed so far by PO:
Head reworked, new seats and stem gaskets. valves left alone. Heads mild polish job.New water pumpnew radiatornew power steering pressure linenew spark plugs (all 8) New fan clutch
Now for the problem
There is literally no power, on the way home it would not get over 50mph. Really felt like the timing was off. so when i got home, i checked the timing and it was off. adjusted timing as directed on the hood and the haynes manual. much better top end but now i cant hardly get off the line
so am i looking at carb troubles (seems like there is a stumble) also when i go up hills the truck bogs and tries to die. This seems to be in line with the floats being bad or adjusted wrong in the carb. What do you guys think?
just turned over 131,000mi the truck was flogged hard and is in bad shape.
also, cant figure out what is wrong with the brake lights. PO pulled the fuse, i plugged in the fuse and nothing happened. put new bulbs in and now the brake lights will not shut off. crawled under the dash and the switch is new. where to look?
Thanks for all the help, i look forward to being an active member on this site.
Modified by 2kredz3 at 9:07 PM 4/19/2008
