1984 300ZX Turbo Wont stay running
A home for 1983–1989 300ZX owners!
Vicious19D
Car: 1984 300ZX Turbo
1988 Celica GT4
1968 Mustang GT Coupe
2010 Ford Adrenalin
Hey guys,new to the site but ive been a auto enthusiast for many years. i mainly build and race 1970's and 80's toyotas but i scored tis nice little 300zx for $1000 bucks. The car will start and run for about 30 seconds and then it dies. It will start again right away but still dies again after 30 sconds. It has new fuel pump and filter, new distributor, new plugs and wires,new air filter and mass air sensor ive also changed out several of the expensive sensors on the intake. The car is an automatic and i noticed that when i took the codes of the ecm it had one for the neutral safety switch throwing an error code. Is it possible that it is whats causing it to have problems with staying running? Im into the car about 1800 now with all of the parts ive put into it but i still cant get it to stay running. Any ideas? I need some help,and i really dont want to sell the damn thing but if i cant get it to run that might be my only choice.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
CHT, O2, IACV. when it fails to restart pull a plug, if it's wet with fuel the issue is likely the CHTS or O2. If the plugs aren't fuel fouled it's likely the iacv.
Vicious19D
1988 Celica GT4
2010 Ford Adrenalin
It always starts right back up but only run for 30-35 seconds. I'll check these out and let you knw what i find
evildky
06 Nissan 350Z GT
That would indicate a bad, dirty or maladjusted iacv.
Vicious19D
1988 Celica GT4
2010 Ford Adrenalin
replaced and reset the IACV. Still the sameproblem but i think Ive got a short somewhere in the system thats causing it to malfunction, now i just need to t rack the short down and fix it
evildky
06 Nissan 350Z GT
Or a bad relay, if everythign works and it cranks and fires then shuts off like maybe the fuel pump looses power after the key rotates back to run form crank?
Return to “300ZX (Z31) Forum”
