1984 300ZX fuel pump relay location
A home for 1983–1989 300ZX owners!
Bluestream
Car: 1984 300ZX
Hi all,
I am helping the GF with her 84 300ZX which is non-running right now. The fuel pump will run only if I jump 12V to the pump leads, and engine will then start and run. The wires going to the pump are only putting out 2.8 Volts. That voltage will stay on for 10 secs after the key is shut off, then I hear a relay click up by the glove box. My first thought is a bad relay for the pump, but I have looked everywhere and cant find the damn relay to test it. I have a Factory shop manual, but cant find the location of the relay. Second thought is a bad computer, or bad wireing...
Any help is appreciated
AZ-ZBum
Car: 05 Nissan Murano
84 Nissan 300ZX Z31 AE
88 Nissan 300ZX Z31 Vert
passenger side b-pillar. look in the door jamb vent.
Bluestream
Car: 1984 300ZX
Of all the places, who would have thought there....Thanks a million...
One more thing, is it normal for the ECM to provide voltage to the fuel pump for 10 secs after the key is turned off? Never seen that before...
AZ-ZBum
That information, as well as the relay location, is found in the factory service manual.
Bluestream
Car: 1984 300ZX
Bluestream wrote: One more thing, is it normal for the ECM to provide voltage to the fuel pump for 10 secs after the key is turned off? Never seen that before...
Anyone??
AZ-ZBum
You can download the FSM from xenonz31.com
Return to “300ZX (Z31) Forum”
