Bigorange1962 »
https://forums.nicoclub.com/bigorange1962-u229728.html
Mon Jan 06, 2014 6:13 pm
Some to both. I've bypassed the relay and the blower works fine and I've replaced the relays twice. This is the second new new blower as well.Straight wired the blower and it works fine.....when it's put together it still does the same, doesn't work with low temps outside. I'm going to replace the resister, it's the only thing I have left besides the ignition switch. I will be checking the outside air flap to make sure it's shut tight, just to make sure there's not any moisture get in and freezing up the motor. Even tho I haven't seen any when I replaced the blower.
