Good evening all, I'm trying to revive my 1983 720 and I've run into a problem. The engine will crank but it's not getting fuel to the motor. new fuel pump (that works) and in-line fuel filter installed, also the tubing from tank to filter, then filter to pump, then to the metal lines that run the length of the truck. What else could the problem be???
